There are a couple of steps involved with getting your AD2PI and Raspberry Pi talking to each other. We've done all the initial footwork and highly recommend downloading the modified Raspbian image below and flashing it to a 8g uSD disk or larger using a simple too such as Etcher or Rufus or following the instructions as described here. If you intend to go with another distribution, or just want to do it yourself, then follow the instructions here to start using your device.
- And much much more. See the PiBakery recipe for more details.
| Stable | Download | Raspbian Buster 10 PiBakery build (Latest build 08/15/2019) |
zip: e87cd27f18a5c07c1e2b75400a08c030 img: 5f3eb62b3862575f2604e41c9808672f | 2019-07-20 updated AlarmDecoder 1.13.8, AlarmDecoder-webapp 0.8.6, Added packages, Built using a PiBakery recipe See the AlarmDecoder PiBakery wiki page. |
| Issues | Download | Raspbian Buster 10 PiBakery build (Missing packages) |
zip: e1190b702baf443ee73e6afb982e4fa7 img: 78e06d89dd41a13a288005dc000bee6c | 2019-07-20 updated AlarmDecoder 1.13.7, AlarmDecoder-webapp 0.8.4, Built using a PiBakery recipe See the AlarmDecoder PiBakery wiki page. |
| Stable | Download | Raspbian Stretch 9.0 PiBakery build | zip: cc7e267d2f3bd377a239b3ebc996f491 img: 275635f7ca7ad70e951bea1f68593c86 | 2018-10-14 updated AlarmDecoder 1.13.4, AlarmDecoder-webapp 0.8.2, Built using a PiBakery recipe See the AlarmDecoder PiBakery wiki page. |
| Stable | Download | Raspbian Jessie 8.0 | zip: 3a001426b1a3a2793bea589cfc93be39 img: c5e50da07e5d084ad76abd591ab605f2 | 2018-05-29 updated AlarmDecoder 1.13.4, AlarmDecoder-webapp 0.8.2, Supports the Raspberry Pi Model B, B+ and B2, and B3. Wifi and Bluetooth are both functional on the Pi 3 |
- Flashing tools quick pick
- Etcher https://www.balena.io/etcher/
- Rufus https://rufus.ie/
- Login
- pi
- Password
- raspberry
- Login
- admin
- Password
- alarmdecoder
