AD2PI Bundle
API
Stable Download 2018-05-29 zip: 3a001426b1a3a2793bea589cfc93be39 img: c5e50da07e5d084ad76abd591ab605f2 2018-05-29 updated AlarmDecoder 1.13.4, AlarmDecoder-webapp 0.8.2, Supports the Raspberry Pi Model B, B+ and B2, and B3. Wifi and Bluetooth are both functional on the Pi 3
Login
pi
Password
raspberry
Login
admin
Password
alarmdecoder
AD2PI case assembly
File:Case assembly doc.pdf
