| Stable | Download | Raspbian Stretch 9.0 PiBakery build | zip: cc7e267d2f3bd377a239b3ebc996f491 img: 275635f7ca7ad70e951bea1f68593c86 | 2018-10-14 updated AlarmDecoder 1.13.4, AlarmDecoder-webapp 0.8.2, Built using a PiBakery recipe See the AlarmDecoder PiBakery wiki page. |
| Stable | Download | Raspbian Jessie 8.0 | zip: 3a001426b1a3a2793bea589cfc93be39 img: c5e50da07e5d084ad76abd591ab605f2 | 2018-05-29 updated AlarmDecoder 1.13.4, AlarmDecoder-webapp 0.8.2, Supports the Raspberry Pi Model B, B+ and B2, and B3. Wifi and Bluetooth are both functional on the Pi 3 |
- Flashing tools quick pick
- Etcher https://www.balena.io/etcher/
- Rufus https://rufus.ie/
- Login
- pi
- Password
- raspberry
- Login
- admin
- Password
- alarmdecoder
