Revision as of 13:25, 9 May 2016 by 10.10.0.14 (Talk)
AD2PI Bundle
Stable Download 2016-04-29 ce5a33fe64535b8ecf526e6e5c9bf356 Pre-configured with webapp. Supports the Raspberry Pi Model B, B+ and B2, and B3. Wifi and Bluetooth are both functional on the Pi 3.
Login
pi
Password
raspberry
Login
admin
Password
alarmdecoder
AD2PI case assembly
File:Case assembly doc.pdf
