| Stable | Download | 2016-03-17 | b8b14b04e319b7ab68828ca4254054f5 | Pre-configured with webapp. Supports the Raspberry Pi Model B, B+ and B2. |
- Login
- pi
- Password
- raspberry
- Login
- admin
- Password
- alarmdecoder
