| Stable | Download | 2015-05-22 | 1cee5630146bdafd4f3a901abe8d2637 | Pre-configured with webapp. Supports the Raspberry Pi Model B, B+ and B2. |
- Login
- pi
- Password
- raspberry
- Login
- admin
- Password
- alarmdecoder
