Revision as of 12:30, 31 December 2014 by 204.10.16.29 (Talk)
IoT webapp architecture
Stable Download 2014-11-06 9907099a484a3f9260ad719704e5d086 Pre-configured with webapp. Supports the Raspberry Pi Model B and B+.
Login
pi
Password
raspberry
Login
admin
Password
alarmdecoder
