- Installed and configured the AlarmDecoder Webapp.
| Stable | Download | 2014-11-06 | 9907099a484a3f9260ad719704e5d086 | Pre-configured with webapp. Supports the Raspberry Pi Model B and B+. |
- Login
- pi
- Password
- raspberry
- Login
- admin
- Password
- alarmdecoder
