Revision as of 14:53, 6 June 2014 by 204.10.16.29 (Talk)
IoT webapp architecture
Stable Download 2014-05-01 0302cf2c27eab5176e8a56bcffc65d83 Pre-configured with ser2sock
Beta Download 2014-06-06 3a9b11bc6d42fac90173443049d4fb68 Pre-configured with ser2sock & webapp
Build the next IoT device
File:PiGPIO IOT.zip
Login
pi
Password
raspberry
Login
admin
Password
alarmdecoder
