Revision as of 11:47, 6 January 2014 by 204.10.16.29 (Talk)
  • Disabled serial console so that the device can use it.
  • Installed ser2sock to expose the AlarmDecoder on your network.
  • Installed the AlarmDecoder Python library.
  • Installed and configured Avahi.
Link Version MD5
Download 2013-12-31 9db3460f6818c1f77c9df677abfadf33
    • At this point you should be able to communicate with the device at /dev/ttAMA0.
