Revision as of 16:20, 3 January 2014 by 204.10.16.29 (Talk)
Link Version MD5
Download 2013-12-31 9db3460f6818c1f77c9df677abfadf33
    • At this point you should be able to communicate with the device at /dev/ttAMA0.
