Introduction
FAQ
Is your panel supported?
| Manufacturer | Model | Revision |
| Vista | 10P | 2.0+ |
| Vista | 10PSIA | 3.0+ |
| Vista | 15P | 5.2+ |
| Vista | 20P / 20PSIA | 5.2+ |
| Vista | 21IP | - |
| First Alert | FA130CP | 2.0+ |
| First Alert | FA130CPSIA | 3.0+ |
| First Alert | FA148CP / FA148CPSIA | 5.2+ |
| First Alert | FA168CPS / FA168CPSSIA | 5.2+ |
Is my AlarmDecoder supported?
All of our devices are currently supported by the AlarmDecoder Modem. However, you do need to flash firmware version 2.2a.8.2 or later onto the AlarmDecoder.
You can find the firmware downloads here.
Do I need to change any settings on my AlarmDecoder?
There is one new setting to enable communication with the panel: COM.
Normally this is set by the AlarmDecoder Modem Configuration utility when you configure your device. Please note that if you flash your firmware AFTER configuring the device then you will need to go save your settings again, or manually enable it as described below.
You can manually enable this setting by connecting to your AlarmDecoder and issuing the following command: CCOM=Y<enter>
Can I use other Long-Range Radio devices at the same time?
The panel bus is limited to a single Long-Range Radio device at a time, since it has a dedicated keypad address for it's functionality.
Normally the AlarmDecoder can coexist on the bus as long as you don't have emulation enabled, but for Compass support it temporarily acts as a radio and needs to be able to communicate with interference.
If you would like to keep your existing radio connected we recommend temporarily disconnecting it when you intend to use the AlarmDecoder Modem and Compass.
Where can I get Compass®?
Setup & Configuration
- Download the AlarmDecoder Modem software using the link provided in your order email or from [Here].
- Run the installer. This will install the modem and any necessary prerequisites.
- Make sure that all keypad applications, terminal clients or other software accessing the AlarmDecoder is closed. One connection is allowed at a time unless you're using the network interface.
- Click Save
- Configure Compass®
- Create a new modem
- Compass® 1.x:
- Select the AlarmDecoder Modem COM port (from the first dropdown) as your COM port.
- Compass® 2.x:
- Click Configure COM ports
- Compass® 1.x:
- Configure the modem
- Compass® 1.x:
- Compass® 2.x:
- Compass® 1.x:
- Open (or create) a Customer
- Test your modem connection
- First Time Communication: Select this if your panel has a default CSID.
- Acct # in Panel: Select this option if the Account number has been programmed on your panel. The Account number in Compass® much match.
- Click Connect
Using The Modem
Troubleshooting
Connection to panel failed
Panel too old
Incorrect CSID
Factory state - default CSID:
CSID set:
Getting Help
- Operating system
- Panel model
- Panel revision
