Revision as of 14:55, 24 June 2015 by 204.10.16.29 (Talk)
  • Support for PC/Mac/Linux as well as Mobile and Tablet browsers
Keypad Interface
Here is an example of a successful device test
Device Testing Success
Main Notification Interface
List of Notification Types
Email
Example of Twilio Notification Configuration
Here is an example of a Twilio Notification configuration
  • Account SID - Your Twilio Account SID
  • Auth Token - Your Twilio User Auth Token
  • To - Number to Send SMS to
  • From - Your valid Twilio Phone Number
Example of Google Talk Notification Configuration
Here is an example of a Google Talk Notification configuration
  • Source Address - Messages will come FROM this address
  • Password - The password for the SOURCE account
  • Destination Address - Messages will go to this address
Example of Pushover.net Notification Configuration
Here is the configuration for a Pushover.net notification
  • API Token - The API Token provided by Pushover for your User
  • User/Group Key - The User or Group Key for your account at Pushover
  • Message Priority - In what priority do you want alarm panel notifications
  • Title of Message - Messages sent to Pushover are titled with this text
Example of Prowl Notification Configuration
Here is an example of a Prowl notification configuration
  • API Key - Your Prowl API Key
  • Application Name - Application to Show in Notifications
  • Message Priority - What priority do you want alarm panel notifications to come through as
Example of NotifyMyAndroid configuration
Here is an example of a NotifyMyAndroid notification configuration
  • API Key - Your NotifyMyAndroid API Key
  • Application Name - Application Name to show in notifications
  • Message Priority - What priority do you want Alarm Panel notifications to come through?
Example of a Growl Notification
An example of a Growl Notification configuration
  • Hostname - The Growl server to send notification to
  • Port - The Growl Server Port
  • Password - The password for the Growl server
  • Title - Notification Title
  • Message Priority - What priority do you want these messages to come through as?
Example of a Custom POST notification
Here is an example configuration for a Custom POST notification
  • POST URL - URL of server to POST data to
  • POST Path - Location on server from URL to post to
  • SSL? - Is the URL SSL or Not
  • POST Type - urlencoded, JSON, or XML POST types supported
  • Custom Values - Here you are able to create your own key/value pairs to send with your notification
If you are not using our image, or an older version of the image, you must perform a few steps to enable Camera Support
  • in the contrib directory of the webapp there is an opencv directory
  • in the opencv directory execute
    • sudo sh opencv.sh
  • Once this is done and installed, you can then configure and view a camera.
Example of Camera Listings
Here you see the interface where it lists current cameras as well as a button for creating a new camera.
Example of Creating Camera
Here we are creating a camera for view in the system
  • Name - The name of the camera for display purposes
  • Snapshot URL - The full URL of the motion jpeg stream for your IP camera
  • Username - The username for authenticating to the camera
  • Password - The password for authenticating to the camera
Host Settings
Found under settings->Host
Example of Host Settings Page
Here you are able to configure your device's hostname, networking, as well as reboot and shutdown the device.
Under Settings, click on Users - you will be presented with this screen
User List
Here you are able to edit current users, or create new users.
By clicking New User, you are then taken to this screen
New User Screen
Here you fill out the user's details and save. The user can now login to the webapp.
