- Multiple User Accounts
- Per-user notifications
- IP Camera integration
- Click "Start!" to continue
- Once you are logged in, go to Settings and click on Notifications. From there, you can edit already configured notifications or click "New Notification" to create a new notification.
Image Coming soon..
Example Coming soon..
