This is the recommended way of starting out with your AD2PI. We've gone ahead and done all the initial work to make it and your Raspberry Pi work together out of the box. Just follow the instructions for flashing the SD card from Raspberry Pi.
| Link | Version | MD5 |
| Download | 2013-12-31 | 9db3460f6818c1f77c9df677abfadf33 |
- At this point you should be able to communicate with the device at /dev/ttAMA0.
