2.2a.8.9b-306
- Temporary filter for numeric section of protocol. Max zone number on this firmware is 99.
2.2a.8.9b-305
- FIX RFX timing issue.
2.2a.8.9-303
- Fix another bug in 'K' command. Reverting back to primary address on # or * keys in Ademco mode.
2.2a.8.
- Release as current stable
2.2a.8.7-299
2.2a.8.7-298
- enable debuging
2.2a.8.7-296
2.2a.8.7-295
2.2a.8.7-294
- Improve K command
- Removed VPLEX support
- Improved VPLEX support. RFX output LOOP1 or 4 and supervisory bit if EOL is wrong
2.2a.8.8
- Major changes.
- DSC.
- The virtual keypad emulation is now identical to a real DSC alpha keypad including programming mode fields.
- DSC/Ademco
- Replaced LRR formate messages with new CID format standardizing alarm reporting across panel types using Contact ID.
- Small changes in section #1
- DSC.
