Revision as of 10:31, 8 December 2020 by 204.10.16.14 (Talk)
R Host Acknowledge the CRC message was valid.
\x01\x01\x01 Send Special Key #1
\x02\x02\x02 Send Special Key #2
\x03\x03\x03 Send Special Key #3
\x04\x04\x04 Send Special Key #4
\x05\x05\x05 Send Special Key #5
\x06\x06\x06 Send Special Key #6
\x07\x07\x07 Send Special Key #7
\x08\x08\x08 Send Special Key #8
a DSC ONLY(deprecated use Special Keys): Arm Away
s DSC ONLY(deprecated use Special Keys): Arm Stay
c DSC ONLY(deprecated use Special Keys): Toggle Chime
0123456789*#<> Send key to panel
Arming
The K command can be used to send a message to the panel from a specific keypad address or keypad partition for DSC. There are two parameters: The address or partition a zero padded 2 digit address or partition and the message to send. The AD2* will stay fixed on this new address until a new K message is received or the AD2* is reset or a \r or \n character is received.
  • K011234\r
  • K1912343\r
Special Keys
Special Key Codes
Code Description Ademco DSC
\x01\x01\x01 Special Key #1 Fire/Prog. Fire
\x02\x02\x02 Special Key #2 Police/Prog. Police
\x03\x03\x03 Special Key #3 Medical/AUX/Prog. Medical/AUX
\x04\x04\x04 Special Key #4 Programmable Stay
\x05\x05\x05 Special Key #5 N/A Away
\x06\x06\x06 Special Key #6 N/A Chime
\x07\x07\x07 Special Key #7 N/A Reset
\x08\x08\x08 Special Key #8 N/A Exit
MODE A [A,D]{1} Decoder panel mode Ademco or DSC.
ADDRESS 18 [0-9]{2} Keypad address assigned to the AlarmDecoder for Ademco and Partition# for DSC.
CONFIGBITS FF04 [0-9a-f]{4} Special settings for the device. See CONFIGBITS for more information.
0x0008 Enable the prefixing of panel messages with !KPM.
0x0010 Disable DSC locking (experimental).
0x0080 enable CRC Delivery confirmation for LRR,EXP,REL etc.
15 Indicates a system issue
17 System specific bits. 4 bits packed into a HEX Nibble [0-9,A-F]
18 Ademco or DSC Mode A or D
If you have a Long Range Radio device attached or have emulation enabled the AlarmDecoder will report LRR messages from the panel to the radio. The format of the data encapsulates the SIA DC-05-1999.09 standard for Contact ID reporting.
  • ARM STAY USER 002 partition 1
    •  !LRR:002,1,CID_3441,ff
  • DAY/NIGHT ALARM ZONE 9 partition 1
    •  !LRR:009,1,CID_1135,ff
  • ALARM CANCEL USER 002 partition 1
    •  !LRR:002,1,CID_1406,ff
  • ARM STAY OPENING user 002 partition 1
    •  !LRR:002,1,CID_1441,ff
!LRR:012,1,CID_1441,ff
Header Event Data Partition CID MESSAGE Report CODE
 !LRR 012 1 CID_1441 ff
CID Message
This is CID message for the event. See below for a description and what (if any) programming fields are required for activation. It is prefixed with "CID_" and then 4 digits that are described in section 5.1.2.2 of the SIA DC-05-1999.09 standard.
Report Code Format
CID_QXYZ
Header Event qualifier Event code
CID_ 1 441
Header
Static string "CID_"
Event qualifier
1 = New Event or Opening
3 = New Restore or Closing
6 = Previously reported condition still present (Status report)
Event code
(3 Hex digits 0-9,B-F) Event codes are 3 hex digits and are broken down in classes by the first digit.
100 Alarms
200 Supervisory
300 Troubles
400 Open/Close REMOTE ACCESS
500 Bypass/Disables
600 TEST/MISC
For more detail on specific report codes see the list see Appendix C in the SIA DC-05-1999.09 standard.
 !AUI Format
Header AUI Data
 !KPE Format
!KPE:18
Header Keypad Address
 !KPE 18
 !ERR Format
!ERR:4,4,4
Header Error list
 !ERR 4,4,4
Error number Description
0 No issues to report
4 Keypress send failure
CRC
The CRC Message container is a wrapper around all of the standard !XXX event messages above with the checksum value at the end. The checksum is a CRC-CCITT-16 with a polynomial of 0x1021 of all of the Event Data bytes. Enable via CONFIGBITS
 !CRC Format
!CRC:!LRR:000,1,CID_1121,ff,282d
Header Event Data CRC
 !CRC  !LRR:000,1,CID_1121,ff 282d
 !VER Format
 !VER Format
Flag Description
VZ Virtual zone expanders
AU AUI support (!AUI)
3X Special Keys (S1-S4) must be sent 3 times to trigger
DD Message deduplication
MF Address mask filter
LR Long range radio messages (!LRR) deprecated see L2
L2 Long range radio messages (!LRR) with CID reporting format
CB Config bits
DS DSC support
ER Error tracking
CR CRC Wrapper around EXP,LRR and other event type messages
  • Boot flash mode
  • Operating mode
  • Error mode
