Revision as of 12:52, 13 September 2018 by 10.10.0.12 (Talk)
R Host Acknowledge the CRC message was valid.
\x01\x01\x01 Send Special Key #1
\x02\x02\x02 Send Special Key #2
\x03\x03\x03 Send Special Key #3
\x04\x04\x04 Send Special Key #4
\x05\x05\x05 Send Special Key #5
\x06\x06\x06 Send Special Key #6
\x07\x07\x07 Send Special Key #7
\x08\x08\x08 Send Special Key #8
a DSC ONLY(deprecated use Special Keys): Arm Away
s DSC ONLY(deprecated use Special Keys): Arm Stay
c DSC ONLY(deprecated use Special Keys): Toggle Chime
0123456789*#<> Send key to panel
Arming
The K command can be used to send a message to the panel from a specific keypad address or keypad partition for DSC. There are two parameters: The address or partition a zero padded 2 digit address or partition and the message to send. The AD2* will stay fixed on this new address until a new K message is received or the AD2* is reset or a \r or \n character is received.
  • K011234\r
  • K1912343\r
Special Keys
Special Key Codes
Code Description Ademco DSC
\x01\x01\x01 Special Key #1 Fire/Prog. Fire
\x02\x02\x02 Special Key #2 Police/Prog. Police
\x03\x03\x03 Special Key #3 Medical/AUX/Prog. Medical/AUX
\x04\x04\x04 Special Key #4 Programmable Stay
\x05\x05\x05 Special Key #5 N/A Away
\x06\x06\x06 Special Key #6 N/A Chime
\x07\x07\x07 Special Key #7 N/A Reset
\x08\x08\x08 Special Key #8 N/A Exit
0x0010 Disable DSC locking (experimental).
0x0080 enable CRC Delivery confirmation for LRR,EXP,REL etc.
15 Indicates a system issue
17 System specific bits. 4 bits packed into a HEX Nibble [0-9,A-F]
18 Ademco or DSC Mode A or D
 !AUI Format
Header AUI Data
 !KPE Format
!KPE:18
Header Keypad Address
 !KPE 18
 !ERR Format
!ERR:4,4,4
Header Error list
 !ERR 4,4,4
Error number Description
0 No issues to report
4 Keypress send failure
CRC
The CRC Message container is a wrapper around all of the standard !XXX event messages above with the checksum value at the end. The checksum is a CRC-CCITT-16 with a polynomial of 0x1021 of all of the Event Data bytes. Enable via CONFIGBITS
 !CRC Format
!CRC:!LRR:000,1,CID_1121,ff,282d
Header Event Data CRC
 !CRC  !LRR:000,1,CID_1121,ff 282d
 !VER Format
 !VER Format
Flag Description
VZ Virtual zone expanders
AU AUI support (!AUI)
3X Special Keys (S1-S4) must be sent 3 times to trigger
DD Message deduplication
MF Address mask filter
LR Long range radio messages (!LRR) deprecated see L2
L2 Long range radio messages (!LRR) with CID reporting format
CB Config bits
DS DSC support
ER Error tracking
CR CRC Wrapper around EXP,LRR and other event type messages
  • Boot flash mode
  • Operating mode
  • Error mode
