| Board Revision | Firmware Version | Revision History |
| Stable | ||
| 2.2+ | 2.2a.8.8 | link |
| Beta | ||
| 2.2+ | 2.2a.8.7-297 | link |
| 2.2+ | 2.2a.8.7a | link |
| 2.2+ | 2.2a.8.5s | link |
| 2.2+ | 2.2a.8.3c | link |
| 2.2+ | 2.2a.8.3b | link |
| Legacy | ||
| 2.2+ | 2.2a.8.6 | link |
| 2.2+ | 2.2a.6 | link |
| 2.0 | 2.1f.10 | - |
| 2.2+ | 2.2a.8.2 | link |
| 2.2+ | 2.2a.3 | - |
| 2.2+ | 2.2a.2 | - |
| 2.0 | 2.1f.0e | - |
| 2.0 | 2.1f.0d | - |
| 2.0 | 1.0f.26 | - |
- Flashing new firmware will not retain device configuration settings
- Download one of the available programs or use the built in firmware uploader in the AlarmDecoder WebApp
- Flash the firmware
- AlarmDecoder WebApp
- Settings -> Advanced -> Firmware Upload
