2.2a.8.7-299
2.2a.8.7-298
- enable debuging
2.2a.8.7-297
- added placeholder for Arming bit. Logic to follow for now it will be static 0.
2.2a.8.7-296
2.2a.8.7-295
2.2a.8.7-294
- Improve K command
2.2a.8.8
- Major changes.
- DSC.
- The virtual keypad emulation is now identical to a real DSC alpha keypad including programming mode fields.
- DSC/Ademco
- Replaced LRR formate messages with new CID format standardizing alarm reporting across panel types using Contact ID.
- Small changes in section #1
- DSC.
