Contents[hide] |
V2.2a.8.7-294
- Changed from letter beta codes to git commit #
- Fixed Chime bit state not tracked when real keypad changes chime mode.
- Was showing "UNAVAILABLE" now shows "CHIME"
- Improve K command
- This cased erroneous address show in "C" command or ! config.
