Revision as of 13:15, 31 May 2017 by 10.10.0.31 (Talk)
\x01\x01\x01 Send Special Key #1
\x02\x02\x02 Send Special Key #2
\x03\x03\x03 Send Special Key #3
\x04\x04\x04 Send Special Key #4
\x05\x05\x05 Send Special Key #5
\x06\x06\x06 Send Special Key #6
\x07\x07\x07 Send Special Key #7
\x08\x08\x08 Send Special Key #8
a DSC ONLY(deprecated use Special Keys): Arm Away
s DSC ONLY(deprecated use Special Keys): Arm Stay
c DSC ONLY(deprecated use Special Keys): Toggle Chime
  • K011234\r
  • K1912343\r
Special Keys
Special Key Codes
Code Description Ademco DSC
\x01\x01\x01 Special Key #1 Fire/Prog. Fire
\x02\x02\x02 Special Key #2 Police/Prog. Police
\x03\x03\x03 Special Key #3 Medical/AUX/Prog. Medical/AUX
\x04\x04\x04 Special Key #4 Programmable Stay
\x05\x05\x05 Special Key #5 N/A Away
\x06\x06\x06 Special Key #6 N/A Chime
\x07\x07\x07 Special Key #7 N/A Reset
\x08\x08\x08 Special Key #8 N/A Exit
15 Indicates a system issue
17 System specific bits. 4 bits packed into a HEX Nibble [0-9,A-F]
18 Ademco or DSC Mode A or D
 !AUI Format
Header AUI Data
 !KPE Format
!KPE:18
Header Keypad Address
 !KPE 18
 !ERR Format
!ERR:4,4,4
Header Error list
 !ERR 4,4,4
Error number Description
0 No issues to report
4 Keypress send failure
 !VER Format
 !VER Format
Flag Description
VZ Virtual zone expanders
AU AUI support (!AUI)
3X Special Keys (S1-S4) must be sent 3 times to trigger
DD Message deduplication
MF Address mask filter
LR Long range radio messages (!LRR) deprecated see L2
L2 Long range radio messages (!LRR) with CID reporting format
CB Config bits
DS DSC support
ER Error tracking
CR CRC Wrapper around EXP,LRR and other event type messages
  • Boot flash mode
  • Operating mode
  • Error mode
