Revision as of 13:22, 30 September 2016 by 10.10.0.14 (Talk)
a DSC ONLY: Arm Away
s DSC ONLY: Arm Stay
c DSC ONLY: Toggle Chime
  • K011234\r
  • K1912343\r
15 Indicates a system issue
17 System specific error report
18 Ademco or DSC Mode A or D
 !AUI Format
Header AUI Data
 !KPE Format
!KPE:18
Header Keypad Address
 !KPE 18
 !ERR Format
!ERR:4,4,4
Header Error list
 !ERR 4,4,4
Error number Description
0 No issues to report
4 Keypress send failure
 !VER Format
 !VER Format
Flag Description
VZ Virtual zone expanders
AU AUI support (!AUI)
3X Special Keys (F1-F4) must be sent 3 times to trigger
DD Message deduplication
MF Address mask filter
LR Long range radio messages (!LRR)
CB Config bits
DS DSC support
ER Error tracking
  • Boot flash mode
  • Operating mode
  • Error mode
