| Command | Description |
| = | Reboot the device. |
| E | Dump error report and clear error history. Error report |
| V | Dump the version, serial number and flags used in the firmware. |
| K | Send message from specific partition or keypad address. Addressed Message |
| \x01\x01\x01 | Send Function Key #1 |
| \x02\x02\x02 | Send Function Key #2 |
| \x03\x03\x03 | Send Function Key #3 |
| \x04\x04\x04 | Send Function Key #4 |
| 0123456789*# | Send key to panel |
- K011234\r
- K1912343\r
| Code | Description |
| \x01\x01\x01 | Function Key #1 |
| \x02\x02\x02 | Function Key #2 |
| \x03\x03\x03 | Function Key #3 |
| \x04\x04\x04 | Function Key #4 |
| Mask | Description |
| [00110011000000003A--],010,[f70700000010808c18020000000000],"ARMED ***STAY** ZONE BYPASSED " | |||
| [00110011000000003A--] | 010 | [f70700000010808c18020000000000] | "ARMED ***STAY** ZONE BYPASSED " |
| Position | Description |
| 15 | Indicates a system issue |
| 17 | System specific error report |
| 18 | Ademco or DSC Mode A or D |
| 19 | Unused |
| 20 | Unused |
| Byte | Addresses |
| 1 | 0-7 |
| 2 | 8-15 |
| 3 | 16-23 |
| 4 | 24-31 |
| !EXP:07,01,01 | |||
| !EXP | 07 | 01 | 01 |
| !REL:12,01,01 | |||
| !REL | 12 | 01 | 01 |
| !RFX:0180036,80 | |||
| !RFX | 0180036 | 80 | |
| Bit | Description |
| 1 | Unknown - Seems that the loop indicators should be ignored if set. |
| 4 | Unknown |
| 5 | Loop #3 indication |
| 6 | Loop #2 indication |
| 7 | Loop #4 indication |
| 8 | Loop #1 indication |
| !LRR:012,1,ARM_STAY | |||
| !LRR | 012 | 1 | ARM_STAY |
| Name | Program Fields | Description |
| ALARM_EXIT_ERROR | *59 | Indicates an error when a zone is not closed during arming |
| TROUBLE | *60 | Indicates that a zone is reporting a tamper or failure |
| BYPASS | *61 | Indicates that a zone has been bypassed |
| ACLOSS | *62 | Indicates that AC power was lost |
| LOWBAT | *63 | Low battery indication |
| TEST_CALL | *64 | Indicates a phone test when in testing mode |
| OPEN | *65, requires *66 | Indicates that the alarm is disarmed |
| ARM_AWAY | *66 | Indicates that the system was armed AWAY |
| ARM_STAY | *66 | Indicates that the system was armed STAY |
| RFLOWBAT | *67 | Low battery indication for the RF transmitter |
| CANCEL | *68 | Indicates that the alarm was canceled after second disarm |
| RESTORE | *70 | Indicates that the alarm was restored |
| TROUBLE_RESTORE | *71 | Indicates that the trouble event was restored |
| BYPASS_RESTORE | *72 | Indicates that the bypassed zonew as restored |
| AC_RESTORE | *73 | Indicates that AC power was restored |
| LOWBAT_RESTORE | *74 | Indicates that the low battery has been restored |
| RFLOWBAT_RESTORE | *75 | Indicates that the low battery on the RF transmitter has been restored. |
| TEST_RESTORE | *76 | Indicates that a zone was restored in testing mode |
| ALARM_PANIC | Indicates that there is a panic | |
| ALARM_FIRE | Indicates that there is a fire | |
| ALARM_ENTRY | Indicates that there was an entry alarm | |
| ALARM_AUX | Indicates that an auxiliary alarm type was triggered | |
| ALARM_AUDIBLE | Indicates that an audible alarm is in progress | |
| ALARM_SILENT | Indicates that there was a silent alarm | |
| ALARM_PERIMETER | Indicates that there was a perimeter alarm |
| !AUI:126600000000656c02456cf5ec01017f0002 | |||
| Header | AUI Data | ||
| !AUI | 126600000000656c02456cf5ec01017f0002 | ||
| !KPE:18 | |||
| Header | Keypad Address | ||
| !KPE | 18 | ||
| !ERR:4,4,4 | |||
| Header | Error list | ||
| !ERR | 4,4,4 | ||
| Error number | Description | ||
| 0 | No issues to report | ||
| 4 | Keypress send failure | ||
| !VER:ffffffff,V2.2a.8.2,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;LR;KE;MK;CB;DS;ER | |||
| Header | Serial number | Firmware version | Firmware capabilities |
| !VER | ffffffff | V2.2a.8.2 | TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;LR;KE;MK;CB;DS;ER |
| Firmware Capabilities | |||
| Flag | Description | ||
| TX | Ability to transmit to the panel | ||
| RX | Ability to receive from the panel | ||
| SM | Supports sending multiple keypresses | ||
| VZ | Virtual zone expanders | ||
| RF | Supports receiving of RF messages from the 5800 series wireless devices (!RFX) | ||
| ZX | Supports receiving of messages from zone expanders (!EXP) | ||
| RE | Supports receiving of messages from relay (!REL) | ||
| AU | AUI support (!AUI) | ||
| 3X | Special Keys (F1-F4) must be sent 3 times to trigger | ||
| CG | Serialized configuration string | ||
| DD | Message deduplication | ||
| MF | Address mask filter | ||
| LR | Long range radio messages (!LRR) | ||
| KE | Keypad event messages (!KPM) | ||
| MK | Multiple keypad emulation (See 'K' command for more information) | ||
| CB | Config bits | ||
| DS | DSC support | ||
| ER | Error tracking | ||
