Introduction
FAQ
Is your panel supported?
Confirming your panel model and revision
List of supported panels
| Manufacturer | Model | Revision |
| Vista | 10P | 2.0+ |
| Vista | 10PSIA | 3.0+ |
| Vista | 15P | 5.2+ |
| Vista | 20P / 20PSIA | 5.2+ |
| First Alert | FA130CP | 2.0+ |
| First Alert | FA130CPSIA | 3.0+ |
| First Alert | FA148CP / FA148CPSIA | 5.2+ |
| First Alert | FA168CPS / FA168CPSSIA | 5.2+ |
While it's technically possible you could make things work without knowing the installer code for your panel, there are a number of things that may need to be changed in the panel programming.
If your panel is currently or was previously monitored you'll likely need to either obtain the CSID and Account # from your alarm company or reset the dialer settings to factory default. This can typically be done by executing *96 while in programming mode.
Again, this is technically possible, but you'd need to convince your alarm company to provide you with the CSID and Account # on your panel.
Does this support ADT branded panels?
Unfortunately ADT utilizes a custom default CSID so it can't be used without knowing what this is. To our knowledge this is undocumented. In theory you may be able to swap the PROM, but this is untested.
Where can I get Compass®?
Compass is available for download on the internet, though we cannot provide any direct links.
Setup & Configuration
- Download the AlarmDecoder Modem software using the link provided in your order email.
- Run the installer. This will install the modem and any necessary prerequisites.
- Make sure that all keypad applications, terminal clients or other software accessing the AlarmDecoder is closed. One connection is allowed at a time.
- Click Save
- Configure Compass®
- Create a new modem
- Compass® 1.x:
- Select the AlarmDecoder Modem Comm port (from the first dropdown) as your COM port.
- Compass® 2.x:
- Click Configure COM ports
- Compass® 1.x:
- Configure the modem
- Compass® 1.x:
- Compass® 2.x:
- Compass® 1.x:
- Open (or create) a Customer
- Test your modem connection
- First Time Communication: Select this if your panel has a default CSID. (Field 36)
- Acct # in Panel: Select this option if the Acct # has been programmed on your panel. (Field 32) The Account number in Compass® much match.
- Click Connect
Using The Modem
Troubleshooting
Connection to panel failed
Panel too old
Check the revision of your panel by following the instructions <here>.
Incorrect CSID
Factory state - default CSID:
CSID set:
Please contact support at alarmdecoder@support.nutech.com and we'll help you figure out what's going on.
Getting Help
If you have issues with the software please feel free to contact us at alarmdecoder@support.nutech.com or post in our forums.
- Operating system
- Panel model
- Panel revision
