Revision as of 11:12, 28 April 2015 by 204.10.16.29 (Talk)
17 Unused
18 Unused
 !AUI Format
Header AUI Data
 !KPE Format
!KPE:18
Header Keypad Address
 !KPE 18
Keypad Address
