Revision as of 20:45, 19 February 2014 by 204.10.16.28 (Talk)
  • Open Source Plugin API
    • C# examples included
  • Network connectible
  • mystuff
  • Program Downloader
  • Zone Tracker
  • HTML5 web browser tab
  • Webcam viewer tab
Operating System Version MD5
Windows 2.0.9 1c1a266edeecf1109ca33f9174ac09da
Linux 2.0.9 a7f8ae95ca5204bdc83531cbcd6bda89
Mac OSX 2.0.9 c00408161e8d38367c180dcfe186fe71
The Windows installer will add these requirements automatically. For OSX and Linux these may need to be installed manually.
