- Open Source Plugin API
- C# examples included
- Network connectible
- mystuff
- Example extension, emails events
- Program Downloader
- Zone Tracker
- HTML5 web browser tab
- Webcam viewer tab
- mystuff
| Operating System | Version | MD5 |
| Windows | 2.0.9 | 1c1a266edeecf1109ca33f9174ac09da |
| Linux | 2.0.9 | a7f8ae95ca5204bdc83531cbcd6bda89 |
| Mac OSX | 2.0.6 | 8187069d78770d8fbd5383d7fc3cd47c |
- The Windows installer will add these requirements automatically. For OSX and Linux these may need to be installed manually.
- .NET or Mono
- Windows: Download .NET
- Linux/OSX: Download Mono
- Gtk#
- Windows: Download Gtk#
- Linux/OSX: The easiest way is to install Monodevelop
- Drivers - AD2USB only
- Windows: Download FTDI drivers
- Linux/OSX: On most distributions the FTDI driver will already be installed.
