Revision as of 00:01, 22 December 2013 by 204.10.16.28 (Talk)
The AlarmDecoder GUI program create a realistic advanced keypad on any computer running Windows, OSX or Linux. With the open source plugin API and provided plugins it is simple to configure email alerts on alarm events as well as preform other automation tasks. The program will run on Linux, OSX, Windows and other operating systems that support C# and Gtk
For Windows the installer will add these automatically. For OSX and Linux these may need to be installed manually
Installer
Download the Windows installer now md5:acbf7ce94661f6e2907ab4a44111de0c
Download the Linux installer now md5:53b093f9ee0addaef85c30e909e6a914
Download the OSX installer now
When you run the program for the first time you will need to set the configuration to communicate with your AD2* device. You can do that from within the program in the "System Menu" or by directly editing the text config files mysettings.conf or alarmdecodergui.exe.config . The application must be restarted in order for config file changes to take effect.
  • Open Source Plugin API
    • C# examples included
  • Network connectible
  • mystuff
    • Email events
  • program downloader
  • zone tracker
  • HTML5 web browser tab
  • Webcam viewer tab
