Firmware
Revision as of 23:45, 21 December 2013 by 204.10.16.28 (Talk)
The current stable firmware is V2.2a.6. It is not possible to brick the AlarmDecoder but it can get into some states that make firmware updates difficult so be patient when updating the firmware in your AlarmDecoder
2.2 (AD2USB)
2.2 (AD2SERIAL)
2.0 (AD2USB)
Board Revision Firmware Version
Stable
2.2+ 2.2a.6
2.0 2.1f.10
Beta
2.2+ 2.2a.8
Legacy
2.2+ 2.2a.3-beta
2.2+ 2.2a.2
2.0 2.1f.0e
2.0 2.1f.0d
2.0 1.0f.26
  4. Flash the firmware
    • AlarmDecoderGUI
    • Console firmware uploader
    • ad2-firmwareupload
