- The AlarmDecoder GUI is program designed to create a realistic keypad interface to your alarm using the AlarmDecoder device. The program will run on Linux, OSX, Windows and other operating systems that support .Net and Gtk.
- These will be autocratically added to your system if needed during the install process
- .Net or Mono
- Gtk#
- ftdi drivers
Installer
- Download the Windows installer now md5:acbf7ce94661f6e2907ab4a44111de0c
- Includes ftdi drivers and Gtk#
- Some systems may require .Net http://www.nutech.com/images/fbfiles/files/dotnetfx40.exe
- Download the Linux installer now md5:53b093f9ee0addaef85c30e909e6a914
- Download the OSX installer now md5:
- When you run the program for the first time you will need to set the configuration to communicate with your AD2* device. You can do that from within the program in the "System Menu" or by directly editing the text config files mysettings.conf or ad2usbgui.exe.config . The application must be restarted in order for config file changes to take effect.
