Revision as of 16:19, 20 December 2013 by 204.10.16.29 (Talk)
The AlarmDecoder GUI is program designed to create a realistic keypad interface to your alarm using the AlarmDecoder device. The program will run on Linux, OSX, Windows and other operating systems that support .Net and Gtk.
  • These will be autocratically added to your system if needed during the install process
    • .Net or Mono
    • Gtk#
    • ftdi drivers
Installer
Download the Windows installer now md5:525eec2ad557cfa71f9a7845f3cb25a7
Download the Linux installer now md5:63f286f5ca7439b5c4129606839a3a48
Download the OSX installer now md5:28f97234837f9dbd2632353eb9036b83
When you run the program for the first time you will need to set the configuration to communicate with your AD2* device. You can do that from within the program in the "System Menu" or by directly editing the text config files mysettings.conf or ad2usbgui.exe.config . The application must be restarted in order for config file changes to take effect.
