| Command | Description |
| = | Reboot the device. |
| \x01\x01\x01 | Send Function Key #1 |
| \x02\x02\x02 | Send Function Key #2 |
| \x03\x03\x03 | Send Function Key #3 |
| \x04\x04\x04 | Send Function Key #4 |
| 0123456789*# | Send key to panel |
| Code | Description |
| \x01\x01\x01 | Function Key #1 |
| \x02\x02\x02 | Function Key #2 |
| \x03\x03\x03 | Function Key #3 |
| \x04\x04\x04 | Function Key #4 |
| Mask | Description |
| [001000010000--------],010,[f70700060010808c08020000],"ARMED ***STAY** ZONE BYPASSED " | |||
| [001000010000--------] | 010 | [f70700060010808c08020000] | "ARMED ***STAY** ZONE BYPASSED " |
| Position | Description |
| 15 | Indicates an issue with a zone |
| 17 | Unused |
| 18 | Unused |
| 19 | Unused |
| 20 | Unused |
| Byte | Addresses |
| 1 | 0-7 |
| 2 | 8-15 |
| 3 | 16-23 |
| 4 | 24-31 |
| !EXP:07,01,01 | |||
| !EXP | 07 | 01 | 01 |
| !REL:12,01,01 | |||
| !REL | 12 | 01 | 01 |
| !RFX:0180036,80 | |||
| !RFX | 0180036 | 80 | |
| Bit | Description |
| 1 | Unknown |
| 4 | Unknown |
| 5 | Loop #3 indication |
| 6 | Loop #2 indication |
| 7 | Loop #4 indication |
| 8 | Loop #1 indication |
| !LRR:012,1,ARM_STAY | |||
| !LRR | 012 | 1 | ARM_STAY |
| Name | Program Fields | Description |
| ALARM_EXIT_ERROR | *59 | Indicates an error when a zone is not closed during arming |
| TROUBLE | *60 | Indicates that a zone is reporting a tamper or failure |
| BYPASS | *61 | Indicates that a zone has been bypassed |
| ACLOSS | *62 | Indicates that AC power was lost |
| LOWBAT | *63 | Low battery indication |
| TEST_CALL | *64 | Indicates a phone test when in testing mode |
| OPEN | *65, requires *66 | Indicates that the alarm is disarmed |
| ARM_AWAY | *66 | Indicates that the system was armed AWAY |
| ARM_STAY | *66 | Indicates that the system was armed STAY |
| RFLOWBAT | *67 | Low battery indication for the RF transmitter |
| CANCEL | *68 | Indicates that the alarm was canceled after second disarm |
| RESTORE | *70 | Indicates that the alarm was restored |
| TROUBLE_RESTORE | *71 | Indicates that the trouble event was restored |
| BYPASS_RESTORE | *72 | Indicates that the bypassed zonew as restored |
| AC_RESTORE | *73 | Indicates that AC power was restored |
| LOWBAT_RESTORE | *74 | Indicates that the low battery has been restored |
| RFLOWBAT_RESTORE | *75 | Indicates that the low battery on the RF transmitter has been restored. |
| TEST_RESTORE | *76 | Indicates that a zone was restored in testing mode |
| ALARM_PANIC | Indicates that there is a panic | |
| ALARM_FIRE | Indicates that there is a fire | |
| ALARM_ENTRY | Indicates that there was an entry alarm | |
| ALARM_AUX | Indicates that an auxiliary alarm type was triggered | |
| ALARM_AUDIBLE | Indicates that an audible alarm is in progress | |
| ALARM_SILENT | Indicates that there was a silent alarm | |
| ALARM_PERIMETER | Indicates that there was a perimeter alarm |
