| Command | Description |
| = | Reboot the device. |
| \x01\x01\x01 | Send Function Key #1 |
| \x02\x02\x02 | Send Function Key #2 |
| \x03\x03\x03 | Send Function Key #3 |
| \x04\x04\x04 | Send Function Key #4 |
| 0123456789*# | Send key to panel |
| Code | Description |
| \x01\x01\x01 | Function Key #1 |
| \x02\x02\x02 | Function Key #2 |
| \x03\x03\x03 | Function Key #3 |
| \x04\x04\x04 | Function Key #4 |
| Mask | Description |
| [001000010000--------],010,[f70700060010808c08020000],"ARMED ***STAY** ZONE BYPASSED " | |||
| [001000010000--------] | 010 | [f70700060010808c08020000] | "ARMED ***STAY** ZONE BYPASSED " |
| Position | Description |
| 15 | Indicates an issue with a zone |
| 17 | Unused |
| 18 | Unused |
| 19 | Unused |
| 20 | Unused |
| Byte | Addresses |
| 1 | 0-7 |
| 2 | 8-15 |
| 3 | 16-23 |
| 4 | 24-31 |
| !EXP:07,01,01 | |||
| !EXP | 07 | 01 | 01 |
| !REL:12,01,01 | |||
| !REL | 12 | 01 | 01 |
| !RFX:0180036,80 | |||
| !RFX | 0180036 | 80 | |
| !LRR:012,1,ARM_STAY | |||
| !LRR | 012 | 1 | ARM_STAY |
