| Command | Description |
| = | Reboot the device. |
| \x01\x01\x01 | Send Function Key #1 |
| \x02\x02\x02 | Send Function Key #2 |
| \x03\x03\x03 | Send Function Key #3 |
| \x04\x04\x04 | Send Function Key #4 |
| 0123456789*# | Send key to panel |
The AlarmDecoder configuration viewed or modified in one of two ways: prompted or programmatically.
| REL | NNNNN | [YN]{4} | Emulation of relay expanders 1-4 |
If you send ! followed by a carriage return you will be prompted for each field. This prompt also includes a basic description of the setting as well as it's current value.
You may hit enter to keep the current value or enter a new one.
Programmatically
You may retrieve all of the devices settings by sending C to the panel followed by a carriage return (\r).
Retrieving AlarmDecoder settings:
| [001000010000--------],010,[f70700060010808c08020000],"ARMED ***STAY** ZONE BYPASSED " | |||
| [001000010000--------] | 010 | [f70700060010808c08020000] | "ARMED ***STAY** ZONE BYPASSED " |
| !EXP:07,01,01 | |||
| !EXP | 07 | 01 | 01 |
| !REL:12,01,01 | |||
| !REL | 12 | 01 | 01 |
| !RFX:0180036,80 | |||
| !RFX | 0180036 | 80 | |
| !LRR:012,1,ARM_STAY | |||
| !LRR | 012 | 1 | ARM_STAY |
