Revision as of 13:59, 17 December 2013 by 204.10.16.29 (Talk)
The AlarmDecoder configuration viewed or modified in one of two ways: prompted or programmatically
If you send ! followed by a carriage return you will be prompted for each field. This prompt also includes a basic description of the setting as well as it's current value.
You may hit enter to keep the current value or enter a new one.
Programmatically
You may retrieve all of the devices settings by sending C to the panel followed by a carriage return (\r).
Retrieving AlarmDecoder settings:
