Newbie here, Got the Network appliance and trying to integrate with Smartthings. I'm following step by step instructions from GitHub and keep getting stuck on the final install step.
"Install SmartApp (via github integration)
Click on My SmartApps
Click Update From Repo (top of page)
Check box for alarmdecoder service
Check Publish (bottom of dialog)
Click Execute Update
Adjust @Field settings as needed at the top of the AlarmDecoder service code and as well as any other noted changes needed for Hubitat or SmartThings in the header and Publish if changes are made.
Select the alarmdecoder: AlarmDecoder service smart app and then select your location on the right and press Set Location. (Click the Simulator if you don't see these options)
Click the Discover button. You may have to hit refresh to get your device to show up. If it doesn't show up make sure you're running an up-to-date version of the webapp and that it is on the same netowrk as your SmartThings HUB.
Click Select Devices and select your AlarmDecoder.
Click Install
Notes
This will generate new devices under My Devices"
I set the location to "Home" (my only one). I do not see a Discover button on the page, but there is an Install button. Under preferences, it lists devices (0).
I'm on the same wifi network as the Smartthings hub. I have the WebApp keypad for AlarmDecoder running in different tab.
Been searching for answer before posting, but still stuck. Any help appreciated
