Cannot update
Cannot update
Postby onlize » Tue May 14, 2019 9:20 am
I login to the WebApp and see that I am 6 commits behind. When I click on Update, the screen flashes and show the red X next to the Update button.
How can I fix it and run update?
Thank you.
onlize
Re: Cannot update
Postby mathewss » Tue May 14, 2019 3:43 pm
If you had the older Raspbian 8 image you will have to manually update via SSH and it would be best to update to the latest image that is Raspbian 9. Backup your settings and restore them into a new image.
If its the newest image I would probably want to see this and see why or what is going on as far as I know the current image has had no issues with updates.
Re: Cannot update
Postby onlize » Wed May 15, 2019 4:56 am
Thank you for your reply. I have this device for a year or longer. How can I check what version of Raspbian do I have?
onlize
Re: Cannot update
Postby onlize » Wed May 15, 2019 1:15 pm
I downloaded the new image. Exported/Imported existing setup and everything works.
Thank you.
onlize
