Can you communicate with the device via telnet localhost 10000? I'm out of ideas. Try emailing support again. If you can get Sean to remote in to your system he can probably figure out what is going on.
Sent from my Pixel 2 using Tapatalk
jasonsf wrote:Can you communicate with the device via telnet localhost 10000? I'm out of ideas. Try emailing support again. If you can get Sean to remote in to your system he can probably figure out what is going on.
jasonsf wrote:Maybe update with git pull both the webapp and Alarmdecoder library and do the install script again? I'm running the latest and it is working.
cd /opt/alarmdecoder
git pull
sudo python setup.py install
cd /opt/alarmdecoder-webapp
git pull
sudo rm instance/db.sqlite
python manage.py initdb
sudo reboot
Users browsing this forum: No registered users and 23 guests
