Duplicated keystrokes sent to pannel
Postby popo128 » Tue Jan 09, 2018 12:00 pm
Hello
My alarm is quite old, not sure which panel is it. From the schematics it resembles vista128 (large board with J7 and J8 headers). It works fine with 3 6160/6150 keypads. all 3 keypads are not addressed (i.e all on adr 31). I can read the panel messages clearly in putty but I'm having problems sending commands to the panel. For example I can arm the panel (#2 or #3) most of the time (3 tries out of 5 succeeds), but I can't disarm it or do something more complicated (such as bypass zones)
Trying to figure out why I can send 2 keystrokes to arm the device but not 4 to disarm I entered the panel clock setting mode through the 6160 keypad. I then positioned the cursor on the minutes section. Sending a "3" keystroke to the panel should increment the minutes field by 1 minute only. Looking at the messages coming back from the panel, it seems like a one key stroke is sent multiple times (or at least the panel think it is pressed multiple times, since I can see the minute count incremented few times after each key stroke. I used the alarm decoder app "custom command" form to send a single "3" keystroke each time, but I'm getting the same results when using putty. Please see log below. Is there anything I can do to solve this ? I bought the device so I'd be able to arm/disarm from remote. I can only do half the work...
In the log below:
green means 1 keystroke recived at panel (minute count incremented by 1)
red means few strokes recieved (minute count incremented more than once)
!Sending..done - single "3" stroke sent by alarmdecoder app
1/9/2018 8:51:49 PM !VER:ffffffff,V2.2a.8.8,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;L2;KE;M2;CB;DS;ER;CR
1/9/2018 8:51:49 PM Found Version String
1/9/2018 8:51:50 PM Sending 'C' command to the AlarmDecoder
1/9/2018 8:51:50 PM !>
1/9/2018 8:51:50 PM !CONFIG>MODE=A&CONFIGBITS=ff04&ADDRESS=31&LRR=N&COM=N&EXP=YNNNN&REL=NNNN&MASK=ffffffff&DEDUPLICATE=N
1/9/2018 8:51:50 PM Found and saving Config String
1/9/2018 8:51:51 PM !Reading configuration.
1/9/2018 8:51:51 PM Sending '\r\n' command to the AlarmDecoder
1/9/2018 8:51:51 PM !UART init.
1/9/2018 8:52:04 PM [00010001000000003A--],003,[f70000008003000c08000000000000],"TIME/DATE - TUE20:55 09/01/17"
1/9/2018 8:52:08 PM [00010001000000003A--],003,[f70000008003000c08000000000000],"TIME/DATE - TUE20:55 09/01/17"
1/9/2018 8:52:13 PM [10010001000000003A--],003,[f70000008003001c08000000000000],"TIME/DATE - TUE20:55 09/01/17"
1/9/2018 8:52:17 PM !Sending..done
1/9/2018 8:52:19 PM [10010001000000003A--],003,[f70000008003001c08000000000000],"TIME/DATE - TUE20:56 09/01/17"
1/9/2018 8:52:21 PM [00010001000000003A--],003,[f70000008003000c08000000000000],"TIME/DATE - TUE20:56 09/01/17"
1/9/2018 8:52:23 PM [00010001000000003A--],003,[f70000008003000c08000000000000],"TIME/DATE - TUE20:56 09/01/17"
1/9/2018 8:52:32 PM !Sending.....done
1/9/2018 8:52:32 PM [00010001000000003A--],003,[f70000008003000c08000000000000],"TIME/DATE - TUE20:57 09/01/17"
1/9/2018 8:52:32 PM [00010001000000003A--],003,[f70000008003000c08000000000000],"TIME/DATE - TUE20:58 09/01/17"
1/9/2018 8:52:32 PM [00010001000000003A--],003,[f70000008003000c08000000000000],"TIME/DATE - TUE20:59 09/01/17"
1/9/2018 8:52:32 PM [00010001000000003A--],003,[f70000008003000c08000000000000],"TIME/DATE - TUE20:01 09/01/17"
1/9/2018 8:52:33 PM [00010001000000003A--],003,[f70000008003000c08000000000000],"TIME/DATE - TUE20:02 09/01/17"
1/9/2018 8:52:45 PM !Sending..done
1/9/2018 8:52:45 PM [00010001000000003A--],003,[f70000008003000c08000000000000],"TIME/DATE - TUE20:03 09/01/17"
1/9/2018 8:52:46 PM [00010001000000003A--],003,[f70000008003000c08000000000000],"TIME/DATE - TUE20:04 09/01/17"
1/9/2018 8:52:53 PM [00010001000000003A--],003,[f70000008003000c08000000000000],"TIME/DATE - TUE20:04 09/01/17"
1/9/2018 8:53:00 PM [00010001000000003A--],003,[f70000008003000c08000000000000],"TIME/DATE - TUE20:04 09/01/17"
1/9/2018 8:53:02 PM !Sending..done
1/9/2018 8:53:03 PM [10010001000000003A--],003,[f70000008003001c08000000000000],"TIME/DATE - TUE20:05 09/01/17"
1/9/2018 8:53:10 PM [00010001000000003A--],003,[f70000008003000c08000000000000],"TIME/DATE - TUE20:05 09/01/17"
1/9/2018 8:53:16 PM [10010001000000003A--],003,[f70000008003001c08000000000000],"TIME/DATE - TUE20:05 09/01/17"
1/9/2018 8:53:18 PM [00010001000000003A--],003,[f70000008003000c08000000000000],"TIME/DATE - TUE20:05 09/01/17"
1/9/2018 8:53:23 PM !Sending..done
popo128
Re: Duplicated keystrokes sent to pannel
Postby kevin » Tue Jan 09, 2018 6:35 pm
You'll have to email support @ ad2usb@support.nutech.com
Users browsing this forum: Baidu [Spider] and 11 guests
