AD2Pi and SmartThings integration error
Re: AD2Pi and SmartThings integration error
Postby jasonsf » Wed Dec 13, 2017 8:04 pm
I can also confirm that the new code works on the Master branch.
Jason
jasonsf
Postby Lyubo » Thu Dec 14, 2017 6:59 am
I was able to install and get everything running with the updated code, however i have a little problem:
When the alarm is on, the device in the app keeps switching between armed and disarmed and after about 15-20 minutes turns the alarm off.
This is what I see under the device history:
https://www.screencast.com/t/wL8LHCtUbR
Any ideas what may cause that?
I will remove and redo everything this weekend in case I did something wrong.
Lyubo
Lyubo
Postby mathewss » Thu Dec 14, 2017 10:11 am
You probably have multiple partitions. Send us raw messages from the alarmdecoder to confirm. Fix would be to setup the address mask to only watch one partition.
Sean
Postby Lyubo » Thu Dec 14, 2017 11:15 am
Thanks for the quick reply Sean! How can I get the raw messages from the alarmdecoder?
Lyubo
Lyubo
Postby mathewss » Thu Dec 14, 2017 11:40 am
You can use the "Log" menu/tab on the webApp then select Live and you can "Copy"
Sean
Postby Lyubo » Mon Dec 25, 2017 2:18 pm
Sorry for the long delay.
Here is what the log look like after I turn on the alarm:
2017-12-14 16:34:55 !RFX:0635639,04
2017-12-14 16:34:51 [00100001000000003A--],008,[f760000f1008008c08020000000000],"ARMED ***STAY*** "
2017-12-14 16:34:50 [10000001100000003A--],008,[f70000300008001c28020000000000]," DISARMED CHIME Ready to Arm "
2017-12-14 16:34:44 [00100001000000003A--],008,[f760000f1008008c08020000000000],"ARMED ***STAY*** "
2017-12-14 16:34:39 [10000001100000003A--],008,[f70000300008001c28020000000000]," DISARMED CHIME Ready to Arm "
2017-12-14 16:34:37 !RFX:0088367,04
2017-12-14 16:34:30 [00100001000000003A--],008,[f760000f1008008c08020000000000],"ARMED ***STAY*** "
2017-12-14 16:34:29 [10000001100000003A--],008,[f70000300008001c28020000000000]," DISARMED CHIME Ready to Arm "
2017-12-14 16:34:20 [00100001000000003A--],008,[f760000f1008008c08020000000000],"ARMED ***STAY*** "
2017-12-14 16:34:19 [10000001100000003A--],008,[f70000300008001c28020000000000]," DISARMED CHIME Ready to Arm "
2017-12-14 16:34:14 [00100001000000003A--],008,[f760000f1008008c08020000000000],"ARMED ***STAY*** "
2017-12-14 16:34:09 [10000001100000003A--],008,[f70000300008001c28020000000000]," DISARMED CHIME Ready to Arm "
2017-12-14 16:34:01 [00100001000000003A--],008,[f760000f1008008c08020000000000],"ARMED ***STAY*** "
2017-12-14 16:33:59 [10000001100000003A--],008,[f70000300008001c28020000000000]," DISARMED CHIME Ready to Arm "
2017-12-14 16:33:53 !RFX:0165293,04
2017-12-14 16:33:51 [00100001000000003A--],008,[f760000f1008008c08020000000000],"ARMED ***STAY*** "
It just goes between armed and disarmed and after awhile it turns off the alarm.
I appreciate any help with this issue.
Lyubo
Lyubo
Postby kevin » Mon Dec 25, 2017 6:12 pm
These are definitely messages for 2 different partitions.
You can adjust your address mask to filter out the 2nd partition if it's not in use - or figure out how to disable it via programming.
Postby Lyubo » Tue Dec 26, 2017 12:35 pm
Thanks, Kevin!
I tried to do it by programming the panel, but that didn't change anything.
How would change the address mask? Sorry, this is all new to me...
Lyubo
Lyubo
Postby kevin » Tue Dec 26, 2017 12:56 pm
In the device setup process there is an "Address Mask" field with an address mask builder, you can select which keypad addresses you want to listen to - you can even put in an existing address mask to find out what addresses it encompasses.
You can find how to calculate the address mask in the protocol documentation from the documentation link in the website header
Postby Lyubo » Tue Dec 26, 2017 1:27 pm
Thanks Kevin! That worked.
I have a different issue now. I cant see any of the zones. here is the error I get in the webapp:
https://www.screencast.com/t/QdBqZHBYX2
Lyubo
Lyubo
Users browsing this forum: No registered users and 20 guests
