AD2Pi - Honeywell vista 15P com issues
Postby safarnss » Mon Dec 25, 2017 4:23 pm
I am totally new to this alarmdecoder thing and raspberry Pi. Hello,
I just bought an Ad2Pi device and having some issue to get started.
My Setup: Honeywell Vista 15PSIA with one 6160 keypad at address 16, a CDMA alarm communicator connected to Alarm out terminals.
I am using your pre-configured image and verified wiring as per instructions. I also updated serial ports to
lrwxrwxrwx 1 root root 7 Dec 9 08:50 /dev/serial0 -> ttyAMA0
lrwxrwxrwx 1 root root 5 Dec 9 08:50 /dev/serial1 -> ttyS0
I can see the status from the panel on the web app and can see all the transaction messages on telnet. However, I am not able send any commands to the the panel (I cant arm, disarm) from the web app. During setup on web app, device testing fails as shown below
Opening device ✔
Saving device configuration ⚠ Test timed out.
Keypad communication (Send) ⚠ Test timed out.
Keypad communication (Receive) ✔
This is the diagnostic log from web app
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1836, in __call__
File "/opt/alarmdecoder-webapp/ad2web/app.py", line 128, in __call__
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1820, in wsgi_app
response = self.make_response(self.handle_exception(e))
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1403, in handle_exception
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1817, in wsgi_app
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1477, in full_dispatch_request
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1381, in handle_user_exception
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1475, in full_dispatch_request
rv = self.dispatch_request()
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1461, in dispatch_request
File "/usr/local/lib/python2.7/dist-packages/flask_login.py", line 792, in decorated_view
return func(*args, **kwargs)
File "/opt/alarmdecoder-webapp/ad2web/decorators.py", line 16, in decorated_function
return f(*args, **kwargs)
File "/opt/alarmdecoder-webapp/ad2web/settings/views.py", line 717, in system_diagnostics
device_settings['serial'] = current_app.decoder.device.serial_number.upper()
AttributeError: 'long' object has no attribute 'up
! C or V command from terminal does not get any response.
Any pointers to troubleshoot this ?
regards
Safar
safarnss
Re: AD2Pi - Honeywell vista 15P com issues
Postby kevin » Mon Dec 25, 2017 6:09 pm
Hi, It sounds like the alarmdecoder is on an address not enabled in the panel. You will have to enter programming mode and enable an address for the alarmdecoder to reside at.
Postby safarnss » Mon Dec 25, 2017 8:01 pm
kevin wrote:Hi, It sounds like the alarmdecoder is on an address not enabled in the panel. You will have to enter programming mode and enable an address for the alarmdecoder to reside at.
Keypad address 18 is enabled (data field 191 is 01 00). I even tried enabling address 20 but the result was same. another observation is that the LED on ad2pi board is flashing , probably twice per second.
safarnss
Postby kevin » Mon Dec 25, 2017 8:03 pm
No response to C or V command is strange - please email support, ad2usb@support.nutech.com
Postby safarnss » Wed Dec 27, 2017 7:54 am
I am yet to hear back from support. Meanwhile, if I am seeing messages from panel via telnet 127.0.0.1 10000, does that mean ser2sock is working properly ?
safarnss
Postby safarnss » Mon Jan 01, 2018 4:45 pm
kevin wrote:No response to C or V command is strange - please email support, ad2usb@support.nutech.com
Is tech support still out of office ? I haven't got any response yet !
safarnss
Postby safarnss » Mon Jan 01, 2018 4:46 pm
safarnss
Postby kevin » Mon Jan 01, 2018 4:47 pm
I honestly have no idea, wish I could help with potential hardware issues but I can't - keep trying to contact them, maybe call during office hours.
Users browsing this forum: No registered users and 12 guests
