Getting this under advanced
Postby wilsonb » Fri Nov 17, 2017 2:15 pm
Getting this under advanced tab section;
werkzeug.routing.BuildError
BuildError: Could not build url for endpoint 'update.update_firmware'. Did you mean 'update.firmware' instead?
Traceback (most recent call last)
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1836, in __call__
File "/opt/alarmdecoder-webapp/ad2web/app.py", line 128, in __call__
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1820, in wsgi_app
response = self.make_response(self.handle_exception(e))
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1403, in handle_exception
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1817, in wsgi_app
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1477, in full_dispatch_request
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1381, in handle_user_exception
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1475, in full_dispatch_request
rv = self.dispatch_request()
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1461, in dispatch_request
File "/usr/local/lib/python2.7/dist-packages/flask_login.py", line 792, in decorated_view
return func(*args, **kwargs)
File "/opt/alarmdecoder-webapp/ad2web/decorators.py", line 16, in decorated_function
return f(*args, **kwargs)
File "/opt/alarmdecoder-webapp/ad2web/settings/views.py", line 692, in advanced
File "/usr/local/lib/python2.7/dist-packages/flask/templating.py", line 128, in render_template
context, ctx.app)
File "/usr/local/lib/python2.7/dist-packages/flask/templating.py", line 110, in _render
rv = template.render(context)
File "/usr/local/lib/python2.7/dist-packages/jinja2/environment.py", line 989, in render
return self.environment.handle_exception(exc_info, True)
File "/usr/local/lib/python2.7/dist-packages/jinja2/environment.py", line 754, in handle_exception
File "/opt/alarmdecoder-webapp/ad2web/templates/settings/advanced.html", line 3, in top-level template code
{% extends 'settings/layout.html' %}
File "/opt/alarmdecoder-webapp/ad2web/templates/settings/layout.html", line 19, in top-level template code
{% set tabs = [
File "/opt/alarmdecoder-webapp/ad2web/templates/layouts/base.html", line 104, in top-level template code
{% block container %}
File "/opt/alarmdecoder-webapp/ad2web/templates/layouts/base.html", line 125, in block "container"
{% block body %}
File "/opt/alarmdecoder-webapp/ad2web/templates/settings/advanced.html", line 26, in block "body"
<li><a href="{{ url_for('update.update_firmware') }}">Firmware Update</a>: Update the firmware on your AlarmDecoder.</li>
File "/usr/local/lib/python2.7/dist-packages/flask/helpers.py", line 312, in url_for
return appctx.app.handle_url_build_error(error, endpoint, values)
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1641, in handle_url_build_error
File "/usr/local/lib/python2.7/dist-packages/flask/helpers.py", line 305, in url_for
force_external=external)
File "/usr/local/lib/python2.7/dist-packages/werkzeug/routing.py", line 1758, in build
raise BuildError(endpoint, values, method, self)
The debugger caught an exception in your WSGI application. You can now look at the traceback which led to the error.
To switch between the interactive traceback and the plaintext one, you can click on the "Traceback" headline. From the text traceback you can also create a paste of it.
wilsonb
Re: Getting this under advanced
Postby kevin » Mon Nov 20, 2017 3:19 pm
I would suggest not using the dev branch, there is no guarantees everything is functional on a dev branch.
