502 Bad Gateway - Services might still be starting
Re: 502 Bad Gateway - Services might still be starting
Postby wilsonb » Tue Nov 14, 2017 4:44 pm
[ser2sock]
daemonize = 1
device = /dev/ttyAMA0
baudrate = 115200
port = 10000
raw_device_mode = 1
preserve_connections = 1
bind_ip = 0.0.0.0
send_terminal_init = 0
device_open_delay = 5000
encrypted = 0
ca_certificate =
ssl_certificate =
ssl_key =
ssl_crl = /etc/ser2sock/ser2sock.crl
wilsonb
Postby kevin » Tue Nov 14, 2017 4:45 pm
wilsonb wrote:daemonize = 1
device = /dev/ttyS0
baudrate = 115200
port = 10000
raw_device_mode = 1
bind_ip = 0.0.0.0
encrypted = 0
ca_certificate =
ssl_certificate =
ssl_key =
Postby wilsonb » Tue Nov 14, 2017 4:46 pm
Looks like the device is still ttyAMA0 :evil:
[ser2sock]
daemonize = 1
baudrate = 115200
port = 10000
raw_device_mode = 1
bind_ip = 0.0.0.0
encrypted = 0
ca_certificate =
ssl_certificate =
ssl_key =
wilsonb
Postby kevin » Tue Nov 14, 2017 4:49 pm
Yes, I'm saying you need to manually edit that and change it now that you've done a raspi update.
You will also want to run these commands to make sure the serial console is disabled still
echo "enable_uart=1" | sudo tee -a /boot/config.txt
sudo sed -i 's/console=serial0,115200/ /g' /boot/cmdline.txt
sudo sed -i 's/kgdbog=ttyAMA0,115200/ /g' /boot/cmdline.txt
Postby wilsonb » Tue Nov 14, 2017 5:21 pm
Ok, now I have to assume again. :evil: :evil: :roll:
Do I change it from ;
to;
device = /dev/ser2sock
wilsonb
Postby kevin » Tue Nov 14, 2017 5:22 pm
As said several times in the thread, you will change it to /dev/ttyS0
Postby wilsonb » Tue Nov 14, 2017 9:45 pm
Nope.. still no joy.
device = /dev/ttyS0
[ser2sock]
daemonize = 1
device = /dev/ttyS0
baudrate = 115200
port = 10000
raw_device_mode = 1
bind_ip = 0.0.0.0
encrypted = 0
ca_certificate =
ssl_certificate =
ssl_key =
wilsonb
Postby kevin » Tue Nov 14, 2017 9:53 pm
Well, all I can suggest is starting over with a fresh image, and NOT doing those things again. They aren't in our instructions anywhere, and obviously will break things if you do them.
The good thing is, you can backup your database - it is located at /opt/alarmdecoder-webapp/instance/db.sqlite
If you really want to avoid starting over, I'm sure the guys at Nu Tech can help you out somehow, try emailing support and see what they say.
Postby timlegge » Wed Nov 15, 2017 7:33 pm
I just did a full upgrade tonight.
apt-get update
apt-get upgrade
apt-get dist-upgrade
pip install pip --upgrade
pip install gunicorn --upgrade
grabbed the latest ser2sock and installed it
Couple of reboots
So, I went in stages:
get ser2sock working again . see viewtopic.php?f=3&t=288 but look at the lower part of the thread where the new updates are listed.
test as listed by telneting to 127.0.0.1 10000 (remember to reboot)
updated alarmdecoder-webapp (followed the instructions on https://github.com/nutechsoftware/alarmdecoder-webapp but DID NOT initialize the database (sudo python manage.py initdb)
I had missed
sudo ln -s /usr/local/bin/gunicorn /usr/bin/gunicorn
that prevented gunicorn from restarting
Tim
timlegge
Postby wilsonb » Fri Nov 17, 2017 7:57 am
OK, this is frustrating..
I started fresh..
It happened again. Now we know it has nothing to do with raspi-config or anything I DID OUT of ordinary.
Was working for days..
The only things changes I just did was, select Dev as a source from main in repository in Advanced. That's what I did last time before this image.
Could that be the problem.?
wilsonb
Users browsing this forum: Baidu [Spider] and 6 guests
