If you have that notification setup and are still experiencing a delay, I would surmise that it isn't set up correctly
Can you check your logs to see if there are errors with regard to that notification?
kevin wrote:If you have that notification setup and are still experiencing a delay, I would surmise that it isn't set up correctly
Thanks. I'll play around with the script and see if I can figure it out. I haven't spent a lot of time with docker so I'll have to do some reading. Maybe I can build a new version of docker outside the repo. Otherwise I'll go through the docker run command and see which parameters are failing and try to fix them for the installed version of docker.kevin wrote:A very old version of docker comes in the apt repo's for stretch, so there are things that are needed to be done a little different.
Restart policy should be --restart always for the one on stretch
not sure about the volumes portion, check your syntax - I had this working on stretch, all I had to change was restart policy and device
device for ad2pi being /dev/ttyS0 on newest releases.
standard_init_linux.go:178: exec user process caused "exec format error"
Users browsing this forum: No registered users and 12 guests
