Smart things device not found
Postby Mysecurity » Thu May 18, 2017 8:29 pm
I went through the setup at https://github.com/nutechsoftware/alarm ... /README.md
When I click refresh to discover the device, no device is ever found? I also tried the enabling smart devices steps. The smart things is showing in the notification section of the alarmdecoder webapp notification section.
Mysecurity
Re: Smart things device not found
Postby kevin » Fri May 19, 2017 7:49 am
Please reboot the network appliance to restart the discovery thread - if it continues to not be able to be discovered, please post logs from the device
Postby Mysecurity » Fri May 19, 2017 8:00 am
I ended up discovering the problem. While on the smart things API pahe, I went to the my hubs section and found it odd none were listed. In the my location section, there were 2 HOME locations, 1 of which had no hib associated. I removed the location that hadno hub associated and followed the process for adding alarmdecoder again. I could then see devices.
Mysecurity
