AD2PI WebApp stuck on testing after DB init
Postby darwin » Fri Mar 10, 2017 3:00 am
I lost my admin password, so I ran the manage.py script to re-init the database, as suggested in related topic in this forum to go through the configuration again. I got stuck on the Device Testing portion of the WebApp set up, it just does not finish. Running webApp version v0.7.1-0-g2e4492f.
I SSH into the Pi and I can telnet to the Alarm Decoder, I can read the configuration, reboot it, activate and deactivate the alarm, etc, so that works.
Any suggestions on what may be going on and how to fix it? Thank you.
darwin
Re: AD2PI WebApp stuck on testing after DB init
Postby darwin » Fri Mar 10, 2017 3:55 am
I kept trying to recover connectivity from the WebApp and now the device has become unresponsive. I will attempt a hard reset (removing power) to see if that get is unstuck.
darwin
Postby kevin » Fri Mar 10, 2017 10:06 am
Are you using our official image or did you follow the manual instructions?
Please list the versions of installed packages as well as your alarmdecoder configuration
What portion of device testing fails? Send? Receive? Open? Do the logs say anything useful?
Postby darwin » Sat Mar 11, 2017 4:18 pm
Hi Kevin,
I got a bundle from you and it is an official image (I did an upgrade from the WebApp) Now, at this point the communication with the Alarm decoder has stopped (it was working before, the WebApp was not, but now I cannot reach the Alarm Decoder), this is the output:
pi@alarmdecoder:~ $ telnet localhost 10000
Trying ::1...
Trying 127.0.0.1...
Connected to localhost.
Escape character is '^]'.
the !* and ^ is what I put in there to check if the Decoder was responding. Now, when I run the ser2sock this is the output:
pi@alarmdecoder:~ $ ser2sock
ser2sock[1638]: [✔] Using config file: /etc/ser2sock/ser2sock.conf
ser2sock[1638]: [✔] Serial 2 Socket Relay version V1.5.2 starting
ser2sock[1638]: [✘] Fatal error binding to server port 10000 errno: 98
ser2sock[1638]: [✘] ERROR initializing listen socket :Address already in use
ser2sock[1638]: [✘] exiting
I cannot check the version of the AlarmDecoder because it is unresponsive
Trying ::1...
Trying 127.0.0.1...
V
and the WebApp version is listed in the previous post.
darwin
Postby darwin » Sat Mar 11, 2017 4:34 pm
One more thing, here is the output of nginx
pi@alarmdecoder:~ $ sudo nginx
nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Address already in use)
nginx: [emerg] bind() to 0.0.0.0:443 failed (98: Address already in use)
nginx: [emerg] still could not bind()
pi@alarmdecoder:~ $
darwin
Postby timlegge » Sat Mar 11, 2017 4:40 pm
Address is in use meens nginx is still running.
sudo nginx restart
darwin wrote:One more thing, here is the output of nginx
pi@alarmdecoder:~ $
timlegge
Postby darwin » Sat Mar 11, 2017 6:44 pm
Thank you for your reply!. I don't think that is the issue. I stopped and restarted ser2sock, nginx and gunicorn, and after that reboot the pi, no change, still cannot telnet to the decoder.
pi@alarmdecoder:~ $ sudo killall nginx
pi@alarmdecoder:~ $ sudo killall ser2sock
pi@alarmdecoder:~ $ sudo killall gunicorn
gunicorn: no process found
pi@alarmdecoder:~ $ sudo service ser2sock start
pi@alarmdecoder:~ $ sudo service nginx start
pi@alarmdecoder:~ $ sudo service gunicorn start
ser2sock[1110]: [✔] Using config file: /etc/ser2sock/ser2sock.conf
ser2sock[1110]: [✔] Serial 2 Socket Relay version V1.5.2 starting
ser2sock[1110]: [✔] Listening socket created on port 10000
ser2sock[1110]: [✔] daemonizing the process
Trying ::1...
Trying 127.0.0.1...
^C
I can however "screen" into the serial port after killing ser2sock
screen /dev/serial0 115200
!Ademco Keypad Emulator V2.2a.8.2
!Copyright (C) 2008-2015 Nu Tech Software Solutions, Inc.
!Reproduction without permission is prohibited
!By Sean Mathews <coder@f34r.com>
!For support email AlarmDecoder@support.nutech.com
!www.AlarmDecoder.com
!Ready. Press ! for configuration.
[10010001000000003A--],002,[f70000008002001c08000000000000],"****DISARMED****  READY TO ARM  "
!VER:ffffffff,V2.2a.8.2,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;LR;KE;MK;CB;DS;ER
so the UART seems to be working well.But looks like something in the configuration of the services is wrong. Thank you again for your help
darwin
Postby kevin » Sat Mar 11, 2017 11:10 pm
Please check your ser2sock configuration file in /etc/ser2sock/ and make sure it is binding to the correct serial port
Also in the webapp if you do not have "Share decoder on your network" checked, the webapp will bind to the serial port directly and ser2sock will fail
As far as the other services "address already in use" usually indicates the services are already running and need to be stopped/started again.
