AD2PI / Raspberry Pi install issue
Re: AD2PI / Raspberry Pi install issue
Postby mastruck » Fri Dec 30, 2016 9:07 pm
Kevin, confirmed that it is version 1.7.4. Attached is a screen grab of the rest of the version command output.
Things that seem to be correct:
1. WebApp SW version (I installed your image without change)
2. AD2Pi wiring (I am getting messages from the Vista P20
3. Keyboard address setup
Most likely remaining issue: WebApp config. I have tried just about every combination I can think of...
nginx version info.JPG (39.97 KiB) Viewed 5632 times
mastruck
Postby mastruck » Fri Dec 30, 2016 9:33 pm
Got it working. I can Arm and Disarm from WebApp. It was an issue with my Chrome browser.
mastruck
Postby kevin » Sat Dec 31, 2016 9:58 am
Glad you got it working - when you had it working previously I just assumed it was something with the appliance, browser compatibility didn't even cross my mind :oops:
Postby mastruck » Sat Dec 31, 2016 11:03 am
So, it was working all along. Oh well, I learned a lot trying to figure it out. SmartThings integration is working as well now after I reinstalled it. :)
Thanks for your help!
Mike
mastruck
Postby dwagne47 » Thu Jan 19, 2017 10:40 am
Hello, I was reading this post since I have similiar issue with my AD2PI and Vista 20P panel. Webapp connects to the panel and I can see messages but no input on the Webapp does anything. I have used Chrome from a Windows laptop and from my android phone with the same results.
When you said your issue was due to Chrome related issues what did you do to resolve your issue? Thanks.
dwagne47
