Used AlarmDecoder Rpi Image but can not telnet
Postby Indy_Larry » Fri Dec 30, 2016 6:37 am
I've used the stock AlarmDecoder Rpi image but for some reason I cannot use telnet. When I try to telnet using the IP address and port 10000 or localhost:100000 I get the following: nodename nor servname provided, or not known
OS - MacOS Sierra
Terminal > Screen > xxx.xxx.xxx.xxx:10000
When I connect a screen to the Rpi I am able to log in and I can also ssh into it.
When I setup the Web gui keyboard I get all green checkmarks
Indy_Larry
Re: Used AlarmDecoder Rpi Image but can not telnet
Postby kevin » Fri Dec 30, 2016 8:38 am
To get this option you have to "Share the alarmdecoder on your network" during local device setup.
Postby Indy_Larry » Fri Dec 30, 2016 11:37 am
Hi Kevin,
I had the box marked to share it. Could I have the wrong path for the alarm decoder /dev/ttyAMA0?
Screen Shot 2016-12-30 at 2.28.49 PM.png (58.16 KiB) Viewed 10481 times
Indy_Larry
Postby kevin » Fri Dec 30, 2016 12:04 pm
Make sure your device is at /dev/ttyAMA0 and that your /etc/ser2sock/ser2sock.conf is using the correct device, then restart services (maybe just reboot) - that setting is correct, but maybe it wasn't checked through initial setup and maybe the ser2sock config didn't update accordingly
Postby Indy_Larry » Fri Dec 30, 2016 12:23 pm
Hi Kevin,
Thanks for your quick replies. So I was able to confirm the set2sock.conf file info. Sorry about this but, how can I go about confirming where the device is located?
Screen Shot 2016-12-30 at 3.23.31 PM.png (30.7 KiB) Viewed 10477 times
Indy_Larry
Postby kevin » Fri Dec 30, 2016 12:41 pm
Kill all services (ser2sock, gunicorn, nginx) and try to attach to the serial port directly
screen /dev/ttyAMA0 115200
exit with Ctrl-A then Ctrl-\
You should see raw device stream at /dev/ttyAMA0 if it is there - if not, maybe /dev/serial0
Postby Indy_Larry » Fri Dec 30, 2016 4:29 pm
Hi Kevin,
After killing those three process and doing the < screen /dev/ttyAMA0 115200 > I was seeing communication to one of my glass break sensors that has been faulting since adding the AD2pi, see attached. Was this what you are hoping to see?
Indy_Larry
Postby kevin » Fri Dec 30, 2016 4:56 pm
Ok, great - that means it is the proper device.
After killing those services, start them back up in the following order:
ser2sock
gunicorn
nginx
However, a reboot should fix it provided the "share device on network" setting stuck.
Postby Indy_Larry » Sat Dec 31, 2016 11:45 am
Hi Kevin,
So I did a reboot last night and I still could not telnet into it. So this morning I went through and I re-confirmed the ser2sock config file. It looked the same. I went through and stopped the three services and doing the Screen /dev/ttyAMA0 115200 and seen data scrolling up in the window I followed your other option and instead of rebooting the Rpi I started each service one-by-one Ser2sock, gunicorn, and then nginx. Still no luck being able to telnet in to it.
Indy_Larry
Postby kevin » Sat Dec 31, 2016 4:26 pm
OK, once you are ssh'd into the pi, try this:
telnet localhost 10000
If ser2sock is running and attached to the device this should work.
