Need help with webapp update
Re: Need help with webapp update
Postby kevin » Mon Mar 07, 2016 1:48 pm
Your alarmdecoder was communicating with your panel properly before?
Postby pyrodex » Mon Mar 07, 2016 2:02 pm
kevin wrote:Your alarmdecoder was communicating with your panel properly before?
Yes everything was working as expected prior to the upgrade in the webapp console. I had it working with port 5000 after a DB reset. Then I went in and did my zones, notifications, and custom buttons and validated it worked again. Then I did the nginx upgrade and reboot and now back to the same status before after the webapp update.
pyrodex
Postby pyrodex » Mon Mar 07, 2016 2:05 pm
I just had to reset my DB again for it to work after another setup. Not sure why but nginx + update is working now.
pyrodex
Postby scut77 » Wed Mar 09, 2016 6:23 pm
Thanks Kevin,
All worked with your instructions. 8-)
Now I see there are some Python Modules missing....
Could you please instruction on how to add the missing modules?
scut77
Postby kevin » Wed Mar 09, 2016 7:22 pm
"sudo pip install <module>"
Users browsing this forum: No registered users and 24 guests
